TwinTurbo.NET: Nissan 300ZX forum - Is it hard to replace an NA water pump and thermostat?
Subject Is it hard to replace an NA water pump and thermostat?
Posted by Havoc300 (Chicago) on January 04, 2011 at 11:56 AM
  This message has been viewed 171 times.
Message Coolant leak around bottom center of motor after the engine is turned off. No leak while engine is running, and the heat is not getting that hot anymore. I replaced the radiator after it had a crack at the inlet neck.
